Target Effector
Target Effector
Updated: 3 Feb 2026
Rotates clones to target a point in space.
This node rotates the clones to target a point described by the cloner. Best used with Falloffs disabled.
Target Source What target source to use.
  • Node : Will target the position of the node used in the “Target Node” input.
  • Current Camera : Will target the position of the current camera.
Affect Heading Toggle whether the rotation heading of the clones will target the target effector.
Affect Pitch Toggle whether the rotation pitch of the clones about the x axis is affected.
Invert Direction Invert the direction of the object’s target.
Target NodeInput a node for the cloners to face.Null
