Ripple Effector
Updated: 8 Jan 2026
Modifies a cloner system with a ripple effect.
Updated: 8 Jan 2026
This node applies a simple ripple animation to the clones it is applied to. The ripple is defined by its speed, sharpness, scale, animation rate, and repeat rate; altering these properties can produce a wide variety of ripple effects.
| Blend Amount | Controls the amount the resulting transforms of each clone after the effector is applied is blended with the original transform. |
| Space |
The transform space the Effector uses to influence the clones.
| Animation Rate | The global animation rate for the ripple animation. Useful for speeding up or slowing down the entire effect. |
| Ripple Speed | Speed at which the ripple moves outward from the ripple origin. |
| Ripple Peak Sharpness | How sharp the peaks of the ripple motion are. |
| Ripple Scale | Scales the microripples within the dominant ripple motion. |
| Ripple Repeat Rate | How quickly the ripple animation repeats after the previous ripple. |
| Direction |
Control how the ripple animation is applied to the Cloner system.
| Update Time Mode |
Change how the clone animation uses time.
| Falloff Mode |
| Falloff Direction |
| Falloff Easing Mode |
| Selection Mode |
Set the mode for Index-Based Weighting.
| Selection Operation |
Set how you want top define the selection.
| Index | The first clone index in the range. |
| Max Index | The last clone index in the range. |
| Index Step | The increment used in “Step” mode. |
| Index Seed | The seed used in “Random In Range” mode. |
| Index Falloff Range | Falloff amount for Index-Based Weighting. |
| Index Falloff Power | The curve power of the falloff for Index-Based Weighting. |
| Position X | Offset the clones x position from the current position. |
| Position Y | Offset the clones y position from the current position. |
| Position Z | Offset the clones z position from the current position. |
| Rotation Heading | Offset the clones y rotation from the current rotation. |
| Rotation Pitch | Offset the clones z rotation from the current rotation. |
| Rotation Bank | Offset the clones x rotation from the current rotation. |
| Scale X | Offset the clones x scale from the current scale. |
| Scale Y | Offset the clones y scale from the current scale. |
| Scale Z | Offset the clones z scale from the current scale. |
| Uniform Scale | Uniformally scale the clones by the same value along all axes. |
| Object Index | Offset the clone’s index from the current clone index. Used to select which child object of the cloner is cloned where. |
| Apply To Position | Apply the position changes from the effector to the clones. |
| Apply To Rotation | Apply the rotation changes from the effector to the clones. |
| Apply To Scale | Apply the scale changes from the effector to the clones. |
| Apply To Object Index | Apply the object index changes from the effector to the clones. |
| Position Apply Mode |
The method by which the effectors position properties are applied to the clone. Affecting the previously applied position values.
| Rotation Apply Mode |
The method by which the effectors rotation properties are applied to the clone. Affecting the previously applied rotation values.
| Scale Apply Mode |
The method by which the effectors scale properties are applied to the clone. Affecting the previously applied scale values.
| Object Index Apply Mode |
The method by which the effectors object index properties are applied to the clone. Affecting the previously applied object index values.
| Procedural Falloff | Use a procedural system to generate falloff from. Useful for creating complex and unconventional falloffs from an Effector. | Procedural Root |
