Rigid Body Effector
Rigid Body Effector
Updated: 8 Jan 2026
Applies a rigid body simulation to a cloner system.
The Rigid Body Effector node turns clones into rigid bodies. The resulting bodies are able to collide with each other, or with other bodies that are part of the same physics system - under the same Rigid Body Root.
If this node is parented via a Rigid Body Root it will be part of the physics system of that Rigid Body Root. Otherwise, this node is capable of acting as its own physics system, allowing for easy rigging of a simple physics system with a single cloner.
For best results ensure that the clones do not overlap in their initial position before dynamics is applied.
Unlike other cloner nodes, this Effector is a simulation node. This means that jumping in time will not produce predictable results, as the simulation needs to process the frames in between.
These properties control the physics settings the clones will be simulated under. Parenting a Physics Root node node will disable many of these properties as the node inherits those parameters instead.
Mode How the Clones are used in a physics simulation.
  • Static : A static rigid body does not move and can’t be moved by physics, but will act as a collider for other dynamic objects.
  • Kinematic : A kinematic rigid body is not moved by physics but has a velocity that can affect dynamic bodies.
  • Disabled : Physics will not be applied, and the object will be ignored for simulation.
Shape Type The shape of the rigid body used for simulation of each clone. Often times, a simpler approximation of a mesh can be used for significantly improved performance.
  • Cloned Objects (Simplified / Convex Hulls) : the cloned geometry attached to the parent cloner is used as rigid body geometry - but simplified convex hulls via the mode specified by Convex Hull Mode. Convex hull simplification is often necessary to ensure objects are suitably low poly and convex, as rigid bodies must be.
  • Boxes : A box, useful for emulating boxy objects
  • Spheres : A sphere, useful for emulating balls or roundish objects.
  • Input 3D Objects : Use the geometry from the Collision Shapes input as the rigid body shapes.
  • Chunked 3D Object : A single, chunked 3D object is used - and each clone uses a chunk. This is suitable when the Rigid Body Effector is linked to a single chunked object via the Chunk Effector Deformer.
  • Cloned Objects (Original Geometry) : The rigid body shape from the cloner node is used.
Convex Hull Mode If the Convex Hull shape is used, determines the convex hull mode used to wrap around the clones geometry.
  • 14 Faces (Capsule) - X-Axis : A simplified capsule with 10 sides pointing along the X axis.
  • 14 Faces (Capsule) - Y-Axis : A simplified capsule with 10 sides pointing along the Y axis.
  • 14 Faces (Capsule) - Z-Axis : A simplified capsule with 10 sides pointing along the Z axis.
Max Velocity The maximum velocity any rigid body in this system can reach.
Max Angular Velocity The maximum angular velocity any rigid body in this system can reach.
Dampening Reduces the velocity and angular velocity of bodies over time.
Smoothing Smooths motion of bodies over frames to remove the visual appearance of jitters in the physics system.
Gravity Gravity strength. Defaults to 9.8 but should be adjusted to reflect the scale of the scene.
Floor Collision Enabled Generates a default floor plane to collide all rigid bodies with.
Floor Height The height of the default floor plane.
Floor Static Friction How much friction the floor has relative to static object.
Floor Friction How much friction the floor has relative to moving objects.
Floor Bounciness How much rigid bodies will bounce off of the floor.
Show Rigid Bodies Displays a debug view of the actual rigid body shapes being used to calculate collisions.
Time Till Idle The amount of time an object can be within the Idle Movement Threshold and remain active.
Idle Movement Threshold The minimum amount a physics object can be moving before it stops receiving updates.
The properties control the physical properties of the clones, dictating how they will behave when they interact with each other or other physics objects in the scene.
Rigid BodiesInput Rigid Bodies from other systems to interact with the clones.Rigid Body
Rigid Body AffectorsInput forces which can move and affect the Rigid Bodies.Force Affector
Collision ShapesInput geometry to use as collision shapes for the rigid bodies instead of the built in shapes or convex hulls.3D Object
