Kill Box Effector
Updated: 8 Jan 2026
Removes clones from a cloner system within a specified area.
Updated: 8 Jan 2026
This node limits areas that clones can be generated in and removes clones which move into its region from the scene. The killbox area is described using the Falloffs defined in the Falloff section.
| Blend Amount | Controls the amount the resulting transforms of each clone after the effector is applied is blended with the original transform. |
| Space |
The transform space in which the Effector is processed.
| Falloff Mode |
| Falloff Direction |
| Falloff Easing Mode |
| Selection Mode |
Set the mode for Index-Based Weighting.
| Selection Operation |
Set how you want top define the selection.
| Index | The first clone index in the range. |
| Max Index | The last clone index in the range. |
| Index Step | The increment used in “Step” mode. |
| Index Seed | The seed used in “Random In Range” mode. |
| Index Falloff Range | Falloff amount for Index-Based Weighting. |
| Index Falloff Power | The curve power of the falloff for Index-Based Weighting. |
| Procedural Falloff | Use a procedural system to generate falloff from. Useful for creating complex and unconventional falloffs from an Effector. | Procedural Root |
