Cloner (Legacy)
Cloner (Legacy)
Updated: 8 Jan 2026
Generates clones in a regular pattern.
This node clones 3D objects in a regular pattern in one of several ways depending on the mode set.
In Iterative Cloning mode, the Transform parameters define the transform that is applied as a delta between the location of the last clone and the next. In Radial and Grid mode the Transform parameters transform the location of the ring or grid.
Position X Changes the x position of all clones from the previous clone.
Position Y Changes the y position of all clones from the previous clone.
Position Z Changes the z position of all clones from the previous clone.
Rotation Heading Changes the x rotation of all clones from the previous clone.
Rotation Pitch Changes the y rotation of all clones from the previous clone.
Rotation Bank Changes the rotation of all clones from the previous clone.
Scale X Changes the x scale of all clones from the previous clone.
Scale Y Changes the y scale of all clones from the previous clone.
Scale Z Changes the z scale of all clones from the previous clone.
Mode Change how the clones are arranged after being spawned.
  • Iterative Cloning : The Cloner node’s transform is applied sequentially, so each clone is translated, scaled and rotated from the previous using the Transform values.
  • 3D Grid : The clones are generated in a 3D Grid, where clones are generated at each grid intersection.
  • Radial : The clones are generated in a radial pattern around the nodes current position.
Rotation Affects Position The rotation of the child object affects the position of the clones.
Scale Affects Position The scale of the child object affects the position of the clones.
Scale Affects Clone Scale The scale of the new clone increases with each clone added.
Only functions if 3D Grid is selected in the Mode attribute.
Grid Count X Number of sections in the grid along the X axis.
Grid Count Y Number of sections in the grid along the Y axis.
Grid Count Z Number of sections in the grid along the Z axis.
Grid Size X The size of the grid in the X axis. The clones are distributed evenly within this size limit.
Grid Size Y The size of the grid in the Y axis. The clones are distributed evenly within this size limit.
Grid Size Z The size of the grid in the Z axis. The clones are distributed evenly within this size limit.
Grid Stagger X Offset alternating clones along the X axis.
Grid Stagger Y Offset alternating clones along the Y axis.
Grid Stagger Z Offset alternating clones along the Z axis.
Grid Fill How much of the grid is filled in, in its centre.
Grid Type Which type of grid is generated.
  • Cubic : The clones are arranged in a regular grid inside a cube.
  • Spherical : The clones are arranged in a regular grid inside a sphere.
  • Cylindrical : The clones are arranged in a regular grid inside a cylinder.
Grid Size Mode Changes how the Grid Size X/Y/Z affect the clones.
  • Total Size : Controls the whole size of the grid.
  • Size Per Clone : Controls the distance between clones on the grid.
Only functions if Radial is selected in the Mode attribute.
Radius The radius of the ring shape.
Radial Start Angle The angular location of the first clone around the ring.
Radial End Angle The angular location of the last clone around the ring.
Radial Plane The planar axis in which the ring is positioned.
Reset Per Clone Transform .
