Node Trail
Node Trail
Updated: 28 Jan 2026
Creates a spline that follows a node.
This node creates a spline that follows the position of a node in the scene. At each frame update, a new point is added to the spline, continuing to grow the splines length. no smoothing is applied to the spline, so large positional changes or erratic motion can appear noisy.
This node outputs a spline which can be input into other nodes which use splines to generate new effects, such as the Spline Extruder or the Particle Spline Emitter.
Update Time Mode How the generated spline updates with relation to the time code.
  • Locked To Timecode : The deformer deformations are locked to the time code and the same time will always yield the same deformations.
  • Running / Looping : The deformer deformations are disconnected from the time code and will loop seamlessly at the end of the layer.
Control how the spline is visualised in the scene for debugging purposes.
Show Spline Show the new spline in the scene.
Trail Source NodeWhich node to follow when drawing the spline.Null
