Freeze Geometry
Freeze Geometry
Updated: 17 Sep 2025
Merges sources of geometry together, and freezes updates to save on processing.
Combines multiple geometry nodes into a single mesh, preserving the materials of the source geometry. The resulting mesh is static, meaning it won’t be regenerated or updated again until the timeline is reset.
Once frozen, the source geometry nodes are disabled from rendering and updating; they will appear hashed out in the nodegraph, with a “frozen” icon on top. Do not hide the source geometry nodes manually or the Freeze Geometry node will be not regenerate them.
When the Freeze Geometry node is disabled or it becomes inactive because it is out of range on the timeline, the source geometry nodes are restored to visibility.
The diffuse/lightmap UV set for the source geometry is laid out onto a grid, with a cell per input geometry node, preserving the uniqueness of these UVs for lightmap baking for use with the Bake Lighting To Object node.
This node is useful for combining several pieces of geometry into one, to optimise complex scenes with lots of nodes. In some cases, substantial performance improvements can be found.
Rendered Lightmap
Geometry SourcesSources of geometry to be combined into a single object.3D Primitive
