Duplicate Geometry
Duplicate Geometry
Updated: 28 Jan 2026
Duplicate input geometry
This node creates a duplicate of any input geometry, to create a copy of the object or to be deformed in a new deformer system. The geometry is duplicated after processing, so any deformers and material properties will also be duplicated. The new object may inherit from the originals material and transforms, or use its own.
Any geometry generating node can be duplicated, including 3D Primitives, Procedural Meshing, and Particle Trails.
This node outputs the normal transformation and translation values, but it also outputs geometry which can be modified with Deformer nodes, or used as a mesh sources for nodes which accept mesh connections, such as the Field Mesh Emitter or the Procedural Mesh.
Retain Source Materials Control whether the materials applied to the source geometry is also applied to the duplicate.
Source Transform Control whether the source transforms of the source geometry is also applied to the duplicate.
GeometrySources of geometry to be duplicated.3D Primitive
