Depth Camera Mesh
Depth Camera Mesh
Updated: 17 Sep 2025
This node generates a mesh from depth camera data.
This node generates a mesh based on Kinect camera data from a Depth Camera Source connected via the “Colour Image Node” input. If no source is connected, this node is ineffective.
The mesh is based on a subdivided plane of quads, displaced by the depth values from the Kinect and projected back from the camera. Polygons with depths that fall outside the clip planes set on the Kinect Source node are clipped out. The resolution of the generated mesh may be reduced using the Mesh Resolution Scale parameter.
The generated mesh may be processed by Deformer nodes, or used as an input to other nodes such as the Particle Mesh Emitter or the Field Mesh Emitter.
The mesh may be rendered as transparent or opaque polygons, lines or points - or all three.
You will need to activate the Kinect camera you want to use by going to Project > Settings > VideoIn/Capture/Kinect Settings and enabling it. Otherwise, it will not be initialized by Notch. This is by design, so Notch does not lock the device from the use by other software when you are not actively using it in Notch.
Point Texture Choose an image texture to be placed at the position of each tracked point.
Max Cameras Active Maximum number of Kinect camera’s active
Mesh Resolution Scale Scales the resolution of the generated mesh - defines the number of pixels in the source image per polygon in the mesh.
Pivot Distance How far the mesh is generated from the pivot.
Max Edge Length Max distance between two neighbouring points in the depth image that will be joined together into a polygon.
Vertex Randomisation How much randomness is added to the positions of each vertex.
Use Depth From Luminance (Fake Depth) Depth values may be taken from an RGB image rather than depth values calculated by the Kinect.
Filter Depths Smooths the Kinect Depths to try to remove noise - generally only suitable for Kinect v1.
Flatten Depth Depth Values are ignored and the mesh is flattened.
Smoothing Iterations Iteratively smoothes the meshes vertices by the number of levels specified, averaging out all the vertices in the mesh and producing a smoother result. Smoothing is done before rendering. High values can impact performance greatly, and may not be temporally stable if the underlying mesh changes.
Invert Mask Enabled Inverts the clipping area.
Flat Shading Toggle flat shading on or off.
Render Z Only When enabled, the 3D object is only rendered to the depth buffer in the main camera render. No colour data is rendered.
Render To Shadows Only Only renders shadows, and not the mesh itself.
Constant Colour Replace the colour image with a solid colour.
Constant Colour Amount How much the constant colour is blended over the colour image values.
Sort Key Changes the render order of the Kinect Mesh node against other transparent objects in the scene.
Colour Image NodeDefines the Kinect source for the mesh. If a Kinect Source is used, both colour and depth data will be taken from the same node. Otherwise only colour data is taken.Depth Camera Source
Mask Image NodeUse a mask image to control which regions are used by the mesh, based on the luminance of the image.Video Loader
Depth Image NodeUse an image to override the depth input from the Kinect Source node. If the connected node is a Kinect source the depth channel will be taken; otherwise the luminance of the colour channel is used as depth data.Video Loader
Project Image NodesProjects images onto the Kinect mesh to colour it.Video Loader
MaterialOverride the default material.Materials
Transform OverrideApply the transforms of another node to this node.Null
