Combine Geometry
Combine Geometry
Updated: 13 Dec 2024
Merge multiple sources of geometry into one.
Combine multiple sources of geometry into one to be used or affected by other nodes. This particularly great for use with cloner systems, where the geometry can be combined together and deformed collectively.
Make Clone UVs Unique Force the UVs of cloned meshes to be combined into a single uv map with each clone taking up a separate island.
Make Diffuse/Lightmap UVs Unique Force the Diffuse UVs to be generated into a single uv map with each mesh taking up a separate island. Useful for baking lighting, so all mesh UVs are treated separately.
Retain Source Materials Keep the source materials and mappings from the input meshes, and apply them to the combined mesh.
Chunks Mode preserve chunks from input geometry or not.
Geometry SourcesSources of geometry to be combined into a single object.3D Primitive
