3D Primitive
3D Primitive
Updated: 28 Jan 2026
Generate a 3D primitive as a mesh
This node generates a 3D primitive mesh, chosen from the meshes Shape Type property. As well as being rendered directly, 3D Primtiives may also be used as an input for various other nodes, including Particle Mesh Emitters, Field Mesh Emitter, Mesh Cloner, and numerous others. A Material Node can also be input to control the meshes material properties.
The 3D Primitive node may be used as a rigid body in a physics system via the Physics Attributes properties. It must be parented under a Rigid Body Root node for physics to be applied.
Shape Type Choose which 3D shape is rendered.
  • Sphere : UV Sphere generated from subdivisions along the longitude and lattitude.
  • Box : Cube with capability for additional subdivisions and bevel.
  • Cylinder : Cylinder generated from subdivisions along the longitude and lattitude, with capability for an additional inner hole and bevel.
  • Torus : Donut shape generated from subdivisions along the longitude and lattitude, with controls over radius and diameter.
  • Icosphere : Primitive shape built from equilateral triangles, which can be subdivided to approximate a sphere.
  • Plane : Flat surface with capability for additional subdivisions and resizing.
  • Cone : Sharp cone with capability for additional subdivisions, bevels, and flattening the peak.
  • Arrow : Simple Arrow shape with various controls over arrow shape, width, length, subdivisions, and many more.
Radius The radius of the primitive, where appropriate.
Size Mode Choose if the properties define the radius or diameter of the shape.
  • Radius : 1 unit measures the distance between center to the bounds
  • Diameter : 1 unit measures the distance between the object bounds
Subdivisions X How many subdivisions along the objects X axis.
Subdivisions Y How many subdivisions along the objects Y axis.
Origin X Set the objects origin point for the X axis.
  • -Size : Sets the objects origin to the objects bound in the negative X direction.
  • Centre (Zero) : Sets the objects origin to the objects center.
  • +Size : Sets the objects origin to the objects bound in the positive X direction.
Origin Y Set the objects origin point for the Y axis.
  • -Size : Sets the objects origin to the objects bound in the negative Y direction.
  • +Size : Sets the objects origin to the objects bound in the positive Y direction.
Origin Z Set the objects origin point for the Z axis.
  • -Size : Sets the objects origin to the objects bound in the negative Z direction.
  • +Size : Sets the objects origin to the objects bound in the positive Z direction.
Primitive Vertex Count Shows the original vertex count of the primtiive at generation.
Primitive Polygon Count Shows the original polygon count of the primtiive at generation.
Post-Deformer Vertex Count Shows the current vertex count of the primtiive after all the deformers have been applied.
Post-Deformer Polygon Count Shows the current polygon count of the primtiive after all the deformers have been applied.
These properties control how the UVs of the mesh are transformed when output for the UV camera. Useful for arranging multiple objects to be output for the same UV Camera.
Show Metrics Displays information about the mesh geometry.
These properties control the behavious of the object in a Physics System.
  • Static : A static rigid body does not move and can’t be moved by physics, but will act as a collider for other dynamic objects. An example could be a floor or wall.
  • Kinematic : A kinematic rigid body is not moved by physics but has a velocity that can affect dynamic bodies. An example could be a moving platform or rotating collider.
  • Dynamic After Collision : A dynamic rigid body has its initial position set by its transform, but transform control is taken over by physics as soon as the object collides.
  • Disabled : Physics will not be applied, and the object will be ignored for simulation.
  • Baked : All the rigid body’s transforms will be controlled by the baked physics data.
GPU Transform Only If selected, the transform of the body is maintained on GPU only. This reduces latency and increases performance but means that parenting to the object, e.g. using it to transform lights or emitters, will not work.
  • 14 Faces (Capsule) - X-Axis : A simplified capsule with 10 sides pointing along the X axis.
  • 14 Faces (Capsule) - Y-Axis : A simplified capsule with 10 sides pointing along the Y axis.
  • 14 Faces (Capsule) - Z-Axis : A simplified capsule with 10 sides pointing along the Z axis.
  • Sphere : A sphere, useful for emulating balls or roundish objects.
  • Box : A box, useful for emulating boxy objects.
  • Plane : A flat infinite plane, useful for setting up solid walls. May only be static or kinematic.
  • 3D Object (Convex Hull) : A convex hull derived from the geometry of the node, with its own modes to set the convex hull generation below.
  • 3D Object (Use Original Geometry) : The original triangle geometry of the node, if applicable. Best used with low poly meshes.
Bake Physics Transforms Bake physics transforms so they are no longer dynamic, but reliably playback and are more performant.
Baked Transform Select the baked physics transform.
