Render To Texture
Render To Texture
Updated: 3 Mar 2025
Render the connected nodes as a video source.
This node renders all its child nodes and their sub-trees to a separate off-screen texture / precomposition. This texture may then be applied anywhere that takes an image or video node as input: materials, video nodes, Image 2D nodes, Image Planes and so on.
Render To Texture nodes can use a different camera to the main scene, if that camera node is parented to the Render To Texture. Similarly, it can also have its own lights and Post Processing nodes which will all be processed into the output texture.
Disable Render To Texture (Pass Through) When enabled, the texture rendering will be ignored and the child nodes will be passed through into the main scene.
Width Width of rendered texture.
Height Height of rendered texture.
Background Colour Change the background colour of the rendered texture.
Use Main Output Aspect Ratio Use the aspect ratio created from the Width and Height attributes.
Rendering Enabled Controls whether the connected scene is re-rendered to the texture.
Use Main Output Eye Position Use the main scene’s eye position for lighting calculations, regardless of where the Render To Texture’s camera is.
Early Evaluation Evaluate the render to texture node earlier in the render pass. This can prevent a blank output appearing for the first frame, but can also cause issues for some nodes which need to be evaluated later.
Flip X Flip the output image on the x axis
Flip Y Flip the output image on the y axis
Affecting LightsChoose which lights will affect connected connected objects.Light
Excluding LightsChoose which lights don’t affect connected connected objects.Light
