2D Primitive
Updated: 28 Jan 2025
Generates a 2D Primitive MeshUpdated: 28 Jan 2025
Generates a 2D Primitive MeshThis node generates a 2D primitive mesh, chosen from the nodes Shape Type property. Typically used in a 2D system under a 2D Root to generate simple 2D shapes, but is equally applicable to 3D scenes.
This node outputs the normal transformation and translation values, but it also outputs geometry which can be modified with Deformer nodes, or used as a mesh sources for nodes which accept mesh connections, such as the Field Mesh Emitter or the Procedural Mesh. A Material Node can also be input to control the meshes material properties.
| Pivot Mode | Control where the pivot point is generated for the object. |
| Pivot Point Selection | In custom mode, filter the points shown on the bounding box for placing the pivot. |
| Pivot Position X | In custom mode, directly edit the x position of the pivot. |
| Pivot Position Y | In custom mode, directly edit the y position of the pivot. |
| Pivot Position Z | In custom mode, directly edit the z position of the pivot. |
| Dynamic Update | Control whether the changes to the pivot dynamically update the object. |
| Shape Type |
Choose which 2D shape is rendered.
| Size Mode |
Choose if the properties define the radius or diameter of the shape.
| Size X | Size of the object along the X axis |
| Size Y | Size of the object along the Y axis |
| Bevel Radius | The radius of the rounded corners of the object. |
| Bevel Subdivisions | Number of subdivisions used to form the bevel. |
| Box Subdivisions X | Number of subdivisions used for the Box shape on the X axis. |
| Box Subdivisions Y | Number of subdivisions used for the Box shape on the Y axis. |
| Origin X |
Set the objects origin point for the X axis.
| Origin Y |
Set the objects origin point for the Y axis.
| Primitive Vertex Count | Shows the original vertex count of the primitive at generation. |
| Primitive Polygon Count | Shows the original polygon count of the primitive at generation. |
| Post-Deformer Vertex Count | Shows the current vertex count of the primitive after all the deformers have been applied. |
| Post-Deformer Polygon Count | Shows the current polygon count of the primitive after all the deformers have been applied. |
| Seen By Rays | Allow the mesh to be seen by the raytracer. When set to 0, the mesh will still render in camera but will be ignored by any raytracing nodes. |
| Render Z Only | When enabled, the 3D object is only rendered to the depth buffer in the main camera render. No colour data is rendered. |
| Render To Shadows Only | When enabled, this object isn’t rendered to the camera but will render shadows still. |
| Per Object Composite Alpha | Overwrites the alpha channel beneath the object, giving simple effect of transparency. Best used when the mesh won’t overlap with other objects, as other meshes will not be seen through the mesh. |
These properties control how the UVs of the mesh are transformed when output for the UV camera. Useful for arranging multiple objects to be output for the same UV Camera.
| UV Scale X | Scale the mesh UV along the X axis. |
| UV Scale Y | Scale the mesh UV along the Y axis. |
| UV Offset X | Move the mesh UV along the X axis. |
| UV Offset Y | Move the mesh UV along the Y axis. |
| Show Metrics | TBC |
These properties control the behavious of the object in a Physics System.
| Static Friction | How much resistance there will be for rigid bodies that are at rest relative to each other to begin moving. |
| Friction | How much other rigid bodies will be able to slide along side this rigid body. When two rigid bodies of different frictions interact, the minimum value is used. |
| Bounciness | How much this rigid body will bounce off of other rigid bodies in the scene. |
| Dynamics Mode |
How the object is used in a physics simulation. Parenting to a Physics Root node node must be done for any physics simulations to occur.
| GPU Transform Only | If selected, the transform of the body is maintained on GPU only. This reduces latency and increases performance but means that parenting to the object, e.g. using it to transform lights or emitters, will not work. |
| Rigid Body Convex Hull Mode |
Determines the convex hull shape generation used to wrap around the node’s geometry. only functions if the Convex Hull shape is selected in the Rigid Body Shape.
| Collision Radius | The radius of collision shape if applicable. |
| Rigid Body Shape |
The shape of the rigid body used for physics simulation. Often times, a simpler approximation of a mesh can be used for significantly improved performance.
| Collision Mode |
Mode for calculating collision if applicable.
| Bake Physics Transforms | Bake physics transforms so they are no longer dynamic, but reliably playback and are more performant. |
| Baked Transform | Select the baked physics transform. |
| Lines Visible | Control whether lines are rendered to the scene from the geometry. |
| Lines Alpha | Change the alpha transparency value of the lines, making them appear see-through. |
| Colour | Change the colour value of the lines. |
| Use Vertex Colours | Colour lines based on the vertex colours of the geometry. |
| Blend Mode |
How the object lines blends with the rest of the content in a 3d scene. See Blend Modes for details.
| Thick Lines | Allow the lines to rendered with thickness, for line effects which can be accurately anti-aliased. |
| Hide Back Face Lines | Hide the lines generated from polygon faces facing away from the camera, where only the back faces of geometry can be seen. |
| Lock Width | Lock the line width to be a consistent width regardless of distance from the camera. Only functions with Thick Lines enabled. |
| Thick Line Width | Control the thickness of all the lines. Only functions with Thick Lines enabled. |
| Show Silhouette Lines | Draws lines along the edges of the object relative to the camera. |
| Show Normal Difference Lines | Draw a line along the edges of the mesh, depending on the angle difference between their mutual faces. |
| Show Unshared Lines | Draw lines along all edges of the shape. |
| Show Other Lines | Show all the lines for each edge of the mesh. |
| Unshared Lines Weight | Control the strength of the unshared lines. |
| Silhouette Lines Weight | Control the strength of the silhouette lines. |
| Normal Difference Lines Weight | Control the strength of the lines generated along the normal angles. |
| Other Lines Weight | Control the strength of the lines for each edge in the mesh. |
| Line Normal Difference Angle | Change the threshold angle between two face normals that will generate a line along their common edge. Only functions with Show Normal Lines enabled. |
| Line Normal Fade Sharpness | How much the drawn normal lines will fade away the closer the edge angle is to the Line Normal Difference Angle. |
| Line Depth Bias | Exaggerate the width of the lines based on the distance to the camera. not functional with Lock Width enabled. |
| Line Silhouette Fade Sharpness | How much the drawn silhouette lines will fade away based on the size of the edge angle to the camera. |
| Material | Override the default material with a material node. | Materials |
| Colour Texture | Override the default material with a material node. | Video Loader |
