Notch Notch Manual 1.0
Clone To Volume
Clone To Volume
Generates Clones which fill the volume of input geometry.
This node clones 3D objects in a regular 3D grid, generating clones in a shell around the mesh polygons. A 3D object node must be connected to the Source Objects input to define the voxelised shape the clones are arranged in for this node to be operational. The connected node must be either a 3D Object, a 3D Primitive or a Text node.
The connected mesh must also be active in the scene by being connected through a valid path to the root node.
Nodes that are to be cloned should be connected to the output of this node. Any geometry node including 3D Objects, 3D Primitives, and Image Planes may be connected, as well as other Cloner systems.
Position XMove along the local x-axis.
Position YMove along the local y-axis.
Position ZMove along the local z-axis.
Rotation HeadingRotate around the local y-axis.
Rotation PitchRotate around the local x-axis.
Rotation BankRotate around the local z-axis.
Scale XScale along the local x-axis.
Scale YScale along the local y-axis.
Scale ZScale along the local z-axis.
PositionToggle inheritance of the Position from the parent.
RotationToggle inheritance of the Rotation from the parent.
ScaleToggle inheritance of the Scale from the parent.
World Position OnlyInherit the world position from the parent only, rotation and scale will be ignored. Overrides above properties.
Inherit TimeToggle inheritance of time from the parent.
Num Voxels XNumber of voxels generated along the x axis.
Num Voxels YNumber of voxels generated along the y axis.
Num Voxels ZNumber of voxels generated along the z axis.
Node Spawn ModeChange the order in which the cloned objects are assigned to clone instances.
Rotate Clone by NormalsRotate clones to match the normals of the volume.
Scale Clones By Voxel SizeScales the cloned objects to match the voxel sizes.
Clone ScaleScale the size of all the clones uniformally.
Rotation StiffnessHow much clones resist rotating.
Scale StiffnessHow much clones resist rotating.
UV Scale X DeltaRelative change to the uv scale along the x of the clone’s material, per clone.
UV Scale Y DeltaRelative change to the uv scale along the y of the clone’s material, per clone.
UV Offset X DeltaRelative change to the uv offset along the x axis of the clone’s material, per clone.
UV Offset Y DeltaRelative change to the uv offset along the y axis of the clone’s material, per clone.
Crop LeftRelative change to the crop on the left of the clone’s uvs, per clone.
Crop Right DeltaRelative change to the crop on the right of the clone’s uvs, per clone.
Crop Top DeltaRelative change to the crop on the top of the clone’s uvs, per clone.
Crop Bottom DeltaRelative change to the crop on the bottom of the clone’s uvs, per clone.
Source ObjectsSource mesh to generate clones from. A mesh must be connected for the cloner to generate clones.3D Object
